[TOC]
The condition sets the static pressure at the patch \( p_p \) based on a specification of the total pressure, \( p_0 \), and pressure drop, \( p_d \), specified as a function of the volumetric flow rate.
\[ p_p = p_0 - p_d \]
Field file entries:
<patchName>
type fanPressure;
file "fanCurve";
outOfBounds clamp;
direction in; // in | out
p0 uniform 0;
value uniform 0;
// Optional entries
U U;
phi phi;
The pressure drop is prescribed as a Foam::interpolationTable in the file given by the file entry, taking the form:
(vfr_1 dp_1)
(vfr_2 dp_2)
(vfr_n dp_n)
