sets the turbulent specific dissipation rate based on the patch turbulence kinetic energy and user-supplied mixing length
\[ \omega_p = \frac{k^{0.5}}{C_{\mu}^{0.25} L} \]
in the event of reverse flow, a zero gradient condition is applied, i.e.
\[ \frac{d \omega}{d x} = 0 \]
The condition is specified in the field file using:
<patchName>
type turbulentMixingLengthFrequencyInlet;
mixingLength 1;
value <field value>;
// Optional entries
Cmu 0.09;
k k;
phi phi;
Copyright © 2017 OpenCFD Ltd.
