The magSqr function object computes the magnitude of the square of an input field.
| input | {vol,surface}<Type>Field | $FOAM_CASE/<time>/<inpField> |
| output file | - | - |
| output field | {vol,surface}ScalarField | $FOAM_CASE/<time>/<outField> |
Example of the magSqr function object by using functions sub-dictionary in system/controlDict file:
magSqr1
type magSqr;
field <inpField>;
result <fieldResult>;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: magSqr | word | yes | - |
postProcess -func "magSqr(<field>)"
