The momentum function object computes linear/angular momentum, reporting integral values and optionally writing the fields.
| input | - | - |
| output field | - | - |
Example of the momentum function object by using functions sub-dictionary in system/controlDict file:
momentum1
type momentum;
regionType all;
writeMomentum yes;
writePosition yes;
writeVelocity yes;
p p;
U U;
rho rho;
rhoRef 1.0;
cylindrical true;
origin (0 0 0);
e1 (1 0 0);
e3 (0 0 1);
writePrecision 8;
writeToFile true;
useUserTime true;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: momentum | word | yes | - |
| regionType | Selection type: all/cellSet/cellZone | word | no | all |
| writeMomentum | Write (linear, angular) momentum fields | bool | no | no |
| writePosition | Write angular position component fields | bool | no | no |
| writeVelocity | Write angular velocity fields | bool | no | no |
| p | Pressure field name | word | no | p |
| U | Velocity field name | word | no | U |
| rho | Density field name | word | no | rho |
| rhoRef | Reference density (incompressible) | scalar | no | 1.0 |
| cylindrical | Use cylindrical coordinates | bool | no | no |
| origin | Origin for cylindrical coordinates | vector | conditional | - |
| name | Name of cellSet/cellZone if required | word | conditional | - |
rhoRef is used.rotation sub-dictionary.For example:
origin (0 0 0);
rotation
type cylindrical;
axis (0 0 1);
