The nearWallFields function object samples near-patch volume fields within an input distance range.
| output file | - | - |
Example of the nearWallFields function object by using functions sub-dictionary in system/controlDict file:
nearWallFields1
type nearWallFields;
fields
(<field1> <outField1>)
(<field2> <outField2>)
patches (<patch1> <patch2> ... <patchN>);
distance 0.01;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: nearWallFields | word | yes | - |
| fields | Names of input-output fields | wordHashTable | yes | - |
| patches | Names of patches to sample | wordList | yes | - |
| distance | Wall-normal distance from patch to sample | scalar | yes | - |
