Scalar transport
Note
Under construction - please check again later
The scalarTransport function object evolves a scalar transport equation, which can be seeded using
  • boundary conditions, e.g. fixed value
  • equation sources, e.g. fvOptions
Usage
Basic operation of the scalarTransport function object comprises:
scalar1
    type            scalarTransport;
    libs            ("libsolverFunctionObjects.so");
For more complete control, the full set of input entries includes:
scalar1
    // Optional entries
    // Name of scalar field to transport, default = 's'
    field           vapour;
    // Name of flux field, default = 'phi'
    phi             phi;
    // Name of density field for compressible cases, default = 'rho'
    rho             rho;
    // Name of phase field to constrain scalar to, default = 'none'
    phase           none;
    // Set the scalar to zero on start/re-start
    resetOnStartUp  no;
    // Name of field to use when looking up schemes from fvSchemes
    // default = <field>
    schemesField    U;
    // Diffusivity
    // Fixed value diffusivity
    D               0.001;
    // Name of field to use as diffusivity, default = 'none'
    nut             none;
    // Run-time selectable sources
    fvOptions
Note
Order of importance when setting the diffusivity
  • Fixed value: D
  • Field value: nut
  • If none, the code will
    • attempt to retrieve the effective viscosity from a turbulence model, or
    • set a value of zero
Sample output
Note
The scalar will only be bounded if evolved using the upwind scheme.
Further information
Example usage:
heatTransfer/chtMultiRegionFoam/windshieldCondensation
Would you like to suggest an improvement to this page? Create an issue
Copyright © 2016 OpenCFD Ltd.
Licensed under the Creative Commons License BY-NC-ND Creative Commons License
