The \( \tilde{\nu} \) transport equation is given by:
\[ \Ddt{\rho \tilde{\nu}} = \div \left( \rho D_\tilde{\nu} \tilde{\nu} \right) + \frac{C_{b2}}{\sigma_{\nu_t}} \rho \mag{\grad \tilde{\nu}}^2 + C_{b1} \rho \tilde{S} \tilde{\nu} \left(1 - f_{t2}\right) - \left(C_{w1} f_w - \frac{C_{b1}}{\kappa^2} f_{t2}\right) \rho \frac{\tilde{\nu}^2}{\tilde{d}^2} + S_\tilde{\nu} \]
where the length scale \( \tilde{d} \) is defined by:
\[ \tilde{d} = \min \left( \Psi C_{DES} \Delta, y \right) \]
and \( \Psi \) is the low Reynolds number correction function:
\[ \Psi^2 = \min \left[ 10^2, \frac{1 - \frac{1 - C_{b1}}{C_{w1} \kappa^2 f_w^{*}} \left[ f_{t2} + \left(1 - f_{t2}\right) f_{v2} \right]}{f_{v1} \max \left(10^{-10}, 1-f_{t2} \right)} \right] \]
| \( \sigma_{\nu_t} \) | \( C_{b1} \) | \( C_{b2} \) | \( C_{w1} \) | \( C_{w2} \) | \( C_{w3} \) |
| 2/3 | 0.1355 | 0.622 | \(\frac{C_{b1}}{\kappa^2} + \frac{1 + C_{b2}}{\sigma_{\nu_t}} \) | 0.3 | 2 |
| \( C_{v1} \) | \( C_{s} \) | \( C_{\mathit{DES}} \) | \( C_{k} \) | \( C_{t3} \) | \( C_{t4} \) | \( f_w^{*} \) |
| 7.1 | 0.3 | 0.65 | 0.07 | 1.2 | 0.5 | 0.424 |
The model is specified using:
LES
turbulence on;
LESModel SpalartAllmarasDES;
// Optional entries
SpalartAllmarasDESCoeffs
// Apply low-Reynolds number correction; default = yes
lowReCorrection yes;
Inlet
Outlet
Walls
References:
Copyright © 2017 OpenCFD Ltd.
