The model equations are the same as used by the DES variant of the model, with a different approximation for \( \tilde{d} \):
\[ \tilde{d} = \max \left( \tilde{f_d} (1 + f_e) L_{RAS} + (1 - \tilde{f_d}) L_{LES}, SMALL \right) \]
The model is specified using:
LES
turbulence on;
LESModel SpalartAllmarasIDDES;
Inlet
Outlet
Walls
References:
Copyright © 2017 OpenCFD Ltd.
