OpenFOAM® v1806: New boundary conditions
New outlet Mach number condition
This pressure boundary condition maintains a (subsonic) Mach number at an outlet patch by dynamically adjusting the static outlet pressure. It makes it possible, for example, to simulate the flow in a pre-turbine engine exhaust manifold without resolving details of the flow inside the turbine.
The formulation is derived from a simple model of the gas flow through a nozzle with fixed geometry. The nozzle flow is assumed to be quasi-steady, 1D, isentropic and compressible.
The accompanying boundary conditions for velocity should be pressureInletOutletVelocity
- Source code
- $FOAM_SRC/TurbulenceModels/compressible/turbulentFluidThermoModels/derivedFvPatchFields/outletMachNumberPressure
- Examples
- $FOAM_TUTORIALS/combustion/reactingFoam/RAS/chokedNozzle
New swirl fan velocity condition
This condition can be used in combination with a cyclic pressure jump condition to simulate a fan. The existing fan pressure jump condition implements the fan-normal momentum gain. This new velocity jump condition adds a swirl component.
The velocity jump can be specified in two ways:
- constant velocity
- constant swirl
In the first mode the velocity is calculated as follows:
Where
represents the current pressure drop across the cyclic,
is the
effective radius,
is the fan efficiency coefficient and
the speed of the
fan (in revolutions-per-minute).
In the second mode the inner (
) and outer (
) radii are provided instead
of
, where for
and
the velocity is given as:
where
is the distance from a patch face to the fan axis. Outside
and
. The input for this mode is:
rInner 0.005;
rOuter 0.01;
origin (0.0453 0.06 0);
If the
is not provided the centroid of the patch is taken.
New wave modelling: irregular waves
A new irregular wave model based on the frequency-direction spectrum has been added to the suite of available wave models.
The wave height is set according to the equation:
![[Picture]](img/v1806-waves-ihc-irregular-00-grad.png)
![[Picture]](img/v1806-waves-ihc-irregular-20-grad.png)
- Source code
- $FOAM_SRC/waveModels/waveGenerationModels/derived/irregularMultiDirectional
- Examples
- $FOAM_TUTORIALS/multiphase/interFoam/laminar/waveExampleIrregularMultiDirection
- Attribution
- These boundary conditions were supplied by the Environmental Hydraulics Institute IHCantabria
- Integration
- The code has been updated by OpenCFD and added to the $FOAM_SRC/waveModels library available to the interFoam family of solvers
