Basic input/output file format
2.2 Basic input/output file format
OpenFOAM needs to read a range of data structures such as strings, scalars, vectors, tensors, lists and fields. The input/output (I/O) format of files is designed to be extremely flexible to enable the user to modify the I/O in OpenFOAM applications as easily as possible. The I/O follows a simple set of rules that make the files extremely easy to understand, in contrast to many software packages whose file format may not only be difficult to understand intuitively but also not be published anywhere. The description of the OpenFOAM file format is described in the following sections.
2.2.1 General syntax rules
The format follows some of the general principles of C++ source code.
  • Files have free form, with no particular meaning assigned to any column and no need to indicate continuation across lines.
  • Lines have no particular meaning except to a // comment delimiter which makes OpenFOAM ignore any text that follows it until the end of line.
  • A comment over multiple lines is done by enclosing the text between /* and */ delimiters.
2.2.2 Dictionaries
OpenFOAM uses dictionaries as the most common means of specifying data. A dictionary is an entity that contains a set of data entries that can be retrieved by the I/O by means of keywords. The keyword entries follow the general format
    <keyword>  <dataEntry1> … <dataEntryN>;
Most entries are single data entries of the form:
    <keyword>  <dataEntry>;
Most OpenFOAM data files are themselves dictionaries containing a set of keyword entries. Dictionaries provide the means for organising entries into logical categories and can be specified hierarchically so that any dictionary can itself contain one or more dictionary entries. The format for a dictionary is to specify the dictionary name followed the entries enclosed in curly braces {} as follows
    <dictionaryName>
        … keyword entries …
2.2.3 The data file header
All data files that are read and written by OpenFOAM begin with a dictionary named FoamFile containing a standard set of keyword entries, listed in Table 2.1.
Keyword
Description
Entry
version
I/O format version
2.0
format
Data format
ascii / binary
location
Path to the file, in "…"
(optional)
class
OpenFOAM class constructed from the data file concerned
typically dictionary or a field, e.g.volVectorField
object
Filename
e.g.controlDict
Table 2.1: Header keywords entries for data files.
The table provides brief descriptions of each entry, which is probably sufficient for most entries with the notable exception of class. The class entry is the name of the C++ class in the OpenFOAM library that will be constructed from the data in the file. Without knowledge of the underlying code which calls the file to be read, and knowledge of the OpenFOAM classes, the user will probably be unable to surmise the class entry correctly. However, most data files with simple keyword entries are read into an internal dictionary class and therefore the class entry is dictionary in those cases.
The following example shows the use of keywords to provide data for a case using the types of entry described so far. The extract, from an fvSolution dictionary file, contains 2 dictionaries, solvers and PISO. The solvers dictionary contains multiple data entries for solver and tolerances for each of the pressure and velocity equations, represented by the p and U keywords respectively; the PISO dictionary contains algorithm controls.
17
18solvers
19{
20    p
21    {
22        solver          PCG;
23        preconditioner  DIC;
24        tolerance       1e-06;
25        relTol          0.05;
26    }
27
28    pFinal
29    {
30        $p;
31        relTol          0;
32    }
33
34    U
35    {
36        solver          smoothSolver;
37        smoother        symGaussSeidel;
38        tolerance       1e-05;
39        relTol          0;
40    }
41}
42
43PISO
44{
45    nCorrectors     2;
46    nNonOrthogonalCorrectors 0;
47    pRefCell        0;
48    pRefValue       0;
49}
50
51
52// ************************************************************************* //
2.2.4 Lists
OpenFOAM applications contain lists, e.g. a list of vertex coordinates for a mesh description. Lists are commonly found in I/O and have a format of their own in which the entries are contained within round braces ( ). There is also a choice of format preceeding the round braces:
simple
the keyword is followed immediately by round braces
        <listName>
            … entries …
numbered
the keyword is followed by the number of elements <n> in the list
        <listName>
        <n>
            … entries …
token identifier
the keyword is followed by a class name identifier Label<Type> where <Type> states what the list contains, e.g. for a list of scalar elements is
        <listName>
        List<scalar>
        <n>        // optional
            … entries …
Note that <scalar> in List<scalar> is not a generic name but the actual text that should be entered.
The simple format is a convenient way of writing a list. The other formats allow the code to read the data faster since the size of the list can be allocated to memory in advance of reading the data. The simple format is therefore preferred for short lists, where read time is minimal, and the other formats are preferred for long lists.
2.2.5 Scalars, vectors and tensors
A scalar is a single number represented as such in a data file. A vector is a VectorSpace of rank 1 and dimension 3, and since the number of elements is always fixed to 3, the simple List format is used. Therefore a vector (1.0, 1.1,1.2)  \relax \special {t4ht= is written:
    (1.0 1.1 1.2)
In OpenFOAM, a tensor is a VectorSpace of rank 2 and dimension 3 and therefore the data entries are always fixed to 9 real numbers. Therefore the identity tensor can be written:
        1 0 0
        0 1 0
        0 0 1
This example demonstrates the way in which OpenFOAM ignores the line return is so that the entry can be written over multiple lines. It is treated no differently to listing the numbers on a single line:
    ( 1 0 0 0 1 0 0 0 1 )
2.2.6 Dimensional units
In continuum mechanics, properties are represented in some chosen units, e.g. mass in kilograms (kg  \relax \special {t4ht=), volume in cubic metres (  3
m   \relax \special {t4ht=), pressure in Pascals (    −1 −2
kgm   s   \relax \special {t4ht=). Algebraic operations must be performed on these properties using consistent units of measurement; in particular, addition, subtraction and equality are only physically meaningful for properties of the same dimensional units. As a safeguard against implementing a meaningless operation, OpenFOAM attaches dimensions to field data and physical properties and performs dimension checking on any tensor operation.
The I/O format for a dimensionSet is 7 scalars delimited by square brackets, e.g.
    [0 2 -1 0 0 0 0]
No. Property SI unit USCS unit
1 Mass kilogram (kg) pound-mass (lbm)
2 Length metre (m) foot (ft)
3 Time
— — — — second (s) — — — —
4 Temperature Kelvin (K) degree Rankine (∘ \relax \special {t4ht=R)
5 Quantity kilogram-mole (kgmol) pound-mole (lbmol)
6 Current
— — — — ampere (A) — — — —
7 Luminous intensity
— — — — candela (cd) — — — —
Table 2.2: Base units for SI and USCS
where each of the values corresponds to the power of each of the base units of measurement listed in Table 2.2. The table gives the base units for the Système International (SI) and the United States Customary System (USCS) but OpenFOAM can be used with any system of units. All that is required is that the input data is correct for the chosen set of units. It is particularly important to recognise that OpenFOAM requires some dimensioned physical constants, e.g. the Universal Gas Constant R  \relax \special {t4ht=, for certain calculations, e.g. thermophysical modelling. These dimensioned constants are specified in a DimensionedConstant sub-dictionary of main controlDict file of the OpenFOAM installation ($WM_PROJECT_DIR/etc/controlDict). By default these constants are set in SI units. Those wishing to use the USCS or any other system of units should modify these constants to their chosen set of units accordingly.
2.2.7 Dimensioned types
Physical properties are typically specified with their associated dimensions. These entries have the format that the following example of a dimensionedScalar demonstrates:
    nu             [0 2 -1 0 0 0 0]  1;
The first nu is the keyword; the next entry is the dimensionSet and the final entry is the scalar value.
2.2.8 Fields
Much of the I/O data in OpenFOAM are tensor fields, e.g. velocity, pressure data, that are read from and written into the time directories. OpenFOAM writes field data using keyword entries as described in Table 2.3.
Keyword Description Example
dimensions Dimensions of field [1 1 -2 0 0 0 0]
internalField Value of internal field uniform (1 0 0)
boundaryField Boundary field see file listing in section 2.2.8
Table 2.3: Main keywords used in field dictionaries.
The data begins with an entry for its dimensions. Following that, is the internalField, described in one of the following ways.
Uniform field
a single value is assigned to all elements within the field, taking the form:
        internalField uniform <entry>;
Nonuniform field
each field element is assigned a unique value from a list, taking the following form where the token identifier form of list is recommended:
        internalField nonuniform <List>;
The boundaryField is a dictionary containing a set of entries whose names correspond to each of the names of the boundary patches listed in the boundary file in the polyMesh directory. Each patch entry is itself a dictionary containing a list of keyword entries. The compulsory entry, type, describes the patch field condition specified for the field. The remaining entries correspond to the type of patch field condition selected and can typically include field data specifying initial conditions on patch faces (see Section 5.1). An example set of field dictionary entries for velocity U are shown below:
17dimensions      [0 1 -1 0 0 0 0];
18
19internalField   uniform (0 0 0);
20
21boundaryField
22{
23    movingWall
24    {
25        type            fixedValue;
26        value           uniform (1 0 0);
27    }
28
29    fixedWalls
30    {
31        type            noSlip;
32    }
33
34    frontAndBack
35    {
36        type            empty;
37    }
38}
39
40// ************************************************************************* //
2.2.9 Directives and macro substitutions
There is additional file syntax that offers great flexibility for the setting up of OpenFOAM case files, namely directives and macro substitutions. Directives are commands that can be contained within case files that begin with the hash (#) symbol. Macro substitutions begin with the dollar ($) symbol.
At present there are 4 directive commands available in OpenFOAM:
#include "<fileName>"
(or #includeIfPresent "<fileName>" reads the file of name <fileName>;
#inputMode
has the following options:
  • #default : provide default value if entry is not already defined
  • #overwrite : silently overwrites existing entries
  • #warn : warn about duplicate entries
  • #error : error if any duplicate entries occur
  • #merge : merge sub-directories when possible (the default mode)
#remove <keywordEntry>
removes any included keyword entry; can take a word or regular expression;
#codeStream
followed by verbatim C++ code, compiles, loads and executes the code on-the-fly to generate the entry.
2.2.10 The #include and #inputMode directives
For example, let us say a user wishes to set an initial value of pressure once to be used as the internal field and initial value at a boundary. We could create a file, e.g. named initialConditions, which contains the following entries:
    pressure 1e+05;
    #inputMode merge
In order to use this pressure for both the internal and initial boundary fields, the user would simply include the following macro substitutions in the pressure field file p:
    #include "initialConditions"
    internalField uniform $pressure;
    boundaryField
        patch1
            type fixedValue;
            value $internalField;
This is a fairly trivial example that simply demonstrates how this functionality works. However, the functionality can be used in many, more powerful ways particularly as a means of generalising case data to suit the user’s needs. For example, if a user has a set of cases that require the same RAS turbulence model settings, a single file can be created with those settings which is simply included in the turbulenceProperties file of each case. Macro substitutions can extend well beyond a single value so that, for example, sets of boundary conditions can be predefined and called by a single macro. The extent to which such functionality can be used is almost endless.
2.2.11 The #codeStream directive
The #codeStream directive takes C++ code which is compiled and executed to deliver the dictionary entry. The code and compilation instructions are specified through the following keywords.
  • code: specifies the code, called with arguments OStream& os and const dictionary& dict which the user can use in the code, e.g. to lookup keyword entries from within the current case dictionary (file).
  • codeInclude (optional): specifies additional C++ #include statements to include OpenFOAM files.
  • codeOptions (optional): specifies any extra compilation flags to be added to EXE_INC in Make/options.
  • codeLibs (optional): specifies any extra compilation flags to be added to LIB_LIBS in Make/options.
Code, like any string, can be written across multiple lines by enclosing it within hash-bracket delimiters, i.e. #{…#}. Anything in between these two delimiters becomes a string with all newlines, quotes, etc. preserved.
An example of #codeStream is given below. The code in the controlDict file looks up dictionary entries and does a simple calculation for the write interval:
startTime       0;
endTime         100;
writeInterval   #codeStream
    code
        scalar start = readScalar(dict.lookup("startTime"));
        scalar end = readScalar(dict.lookup("endTime"));
        label nDumps = 5;
        os << ((end - start)/nDumps);
