Standard libraries
A.3 Standard libraries
The libraries with the OpenFOAM distribution are in the $FOAM_LIB/$WM_OPTIONS directory, reached quickly by typing lib at the command line. Again, the names are prefixed by lib and reasonably descriptive, e.g. incompressibleTransportModels contains the library of incompressible transport models. The library source code is typically located in the $FOAM_SRC directory, easily reached by typing src in the command line. Other libraries devoted to specific physical models for specific solvers may be located separately with the solver source code. For ease of presentation, the libraries are separated into two types:
General libraries
those that provide general classes and associated functions listed in Table A.3;
Model libraries
those that specify models used in computational continuum mechanics, listed in Table A.4, Table A.5 and Table A.6.
Library of basic OpenFOAM tools — OpenFOAM
algorithms
Algorithms
containers
Container classes
db
Database classes
dimensionedTypes
dimensioned<Type> class and derivatives
dimensionSet
dimensionSet class
fields
Field classes
global
Global settings
graph
graph class
interpolations
Interpolation schemes
matrices
Matrix classes
memory
Memory management tools
meshes
Mesh classes
primitives
Primitive classes
Finite volume method library — finiteVolume
cfdTools
CFD tools
fields
Volume, surface and patch field classes; includes boundary conditions
finiteVolume
Finite volume discretisation
fvMatrices
Matrices for finite volume solution
fvMesh
Meshes for finite volume discretisation
interpolation
Field interpolation and mapping
surfaceMesh
Mesh surface data for finite volume discretisation
volMesh
Mesh volume (cell) data for finite volume discretisation
Post-processing libraries
sampling
Tools for sampling point, line and surface field data
fieldFunctionObjects
Field function objects including field averaging, min/max, etc.
forces
Tools for post-processing force/lift/drag data with function objects
runTimePostProcessing
Image generation and manipulation using function objects
lagrangianFunctionObjects
Lagrangian cloud-based function objects
solverFunctionObjects
Solver-based function objects, e.g. adding scalar transport
utilityFunctionObjects
Utility function objects
Solution and mesh manipulation libraries
snappyMesh
Library of functionality for the snappyHexMesh utility
blockMesh
Library of functionality for the blockMesh utility
dynamicMesh
For solving systems with moving meshes
dynamicFvMesh
Library for a finite volume mesh that can move and undergo topological changes
edgeMesh
For handling edge-based mesh descriptions
fvMotionSolvers
Finite volume mesh motion solvers
ODE
Solvers for ordinary differential equations
meshTools
Tools for handling a OpenFOAM mesh
surfMesh
Library for handling surface meshes of different formats
triSurface
For handling standard triangulated surface-based mesh descriptions
topoChangerFvMesh
Topological changes functionality (largely redundant)
Lagrangian particle tracking libraries
basic
Basic Lagrangian, or particle-tracking, solution scheme
coalCombustion
Coal dust combustion modelling
distributionModels
Particle distribution function modelling
dsmc
Direct simulation Monte Carlo method modelling
intermediate
Particle-tracking kinematics, thermodynamics, multispecies reactions, particle forces, etc.
molecule
Molecule classes for molecular dynamics
molecularMeasurements
For making measurements in molecular dynamics
potential
Intermolecular potentials for molecular dynamics
solidParticle
Solid particle implementation
spray
Liquid spray and injection modelling
Miscellaneous libraries
conversion
Tools for mesh and data conversions
decompositionMethods
Tools for domain decomposition
engine
Tools for engine calculations
fileFormats
Core routines for reading/writing data in some third-party formats
genericFvPatchField
A generic patch field
MGridGenGAMGAgglomeration
Library for cell agglomeration using the MGridGen algorithm
pairPatchAgglomeration
Primitive pair patch agglomeration method
OSspecific
Operating system specific functions
randomProcesses
Tools for analysing and generating random processes
Parallel libraries
distributed
Tools for searching and IO on distributed surfaces
reconstruct
Mesh/field reconstruction library
scotchDecomp
Scotch domain decomposition library
ptsotchDecomp
PTScotch domain decomposition library
Table A.3: Shared object libraries for general use.
Basic thermophysical models — basicThermophysicalModels
hePsiThermo
General thermophysical model calculation based on enthalpy h  \relax \special {t4ht= or internal energy e  \relax \special {t4ht=, and compressibility ψ  \relax \special {t4ht=
heRhoThermo
General thermophysical model calculation based on enthalpy h  \relax \special {t4ht= or internal energy e  \relax \special {t4ht=, and density ρ  \relax \special {t4ht=
pureMixture
General thermophysical model calculation for passive gas mixtures
Reaction models — reactionThermophysicalModels
hePsiMixtureThermo
Calculates enthalpy for combustion mixture based on enthalpy h  \relax \special {t4ht= or internal energy e  \relax \special {t4ht=, and ψ  \relax \special {t4ht=
heRhoMixtureThermo
Calculates enthalpy for combustion mixture based on enthalpy h  \relax \special {t4ht= or internal energy e  \relax \special {t4ht=, and ρ  \relax \special {t4ht=
heheuMixtureThermo
Calculates enthalpy h  \relax \special {t4ht= or internal energy e  \relax \special {t4ht= for unburnt u  \relax \special {t4ht= gas and combustion mixture
homogeneousMixture
Combustion mixture based on normalised fuel mass fraction b  \relax \special {t4ht=
inhomogeneousMixture
Combustion mixture based on b  \relax \special {t4ht= and total fuel mass fraction ft  \relax \special {t4ht=
veryInhomogeneousMixture
Combustion mixture based on b  \relax \special {t4ht=, ft  \relax \special {t4ht= and unburnt fuel mass fraction fu  \relax \special {t4ht=
dieselMixture
Combustion mixture based on ft  \relax \special {t4ht= and fu  \relax \special {t4ht=
basicMultiComponentMixture
Basic mixture based on multiple components
multiComponentMixture
Derived mixture based on multiple components
reactingMixture
Combustion mixture using thermodynamics and reaction schemes
egrMixture
Exhaust gas recirculation mixture
Radiation models — radiationModels
fvDOM
Finite volume discrete ordinate method
P1
P1 model
solarLoad
Solar load radiation model
viewFactor
View factor radiation model
Laminar flame speed models — laminarFlameSpeedModels
constLaminarFlameSpeed
Constant laminar flame speed
GuldersLaminarFlameSpeed
Gulder’s laminar flame speed model
GuldersEGRLaminarFlameSpeed
Gulder’s laminar flame speed model with exhaust gas recirculation modelling
Barotropic compressibility models — barotropicCompressibilityModels
linear
Linear compressibility model
Chung
Chung compressibility model
Wallis
Wallis compressibility model
Thermophysical properties of gaseous species — specie
icoPolynomial
Incompressible polynomial equation of state, e.g. for liquids
perfectGas
Perfect gas equation of state
eConstThermo
Constant specific heat cp  \relax \special {t4ht= model with evaluation of internal energy e  \relax \special {t4ht= and entropy s  \relax \special {t4ht=
hConstThermo
 p  \relax \special {t4ht= model with evaluation of enthalpy h  \relax \special {t4ht= and entropy s  \relax \special {t4ht=
hPolynomialThermo
cp  \relax \special {t4ht= evaluated by a function with coefficients from polynomials, from which h  \relax \special {t4ht=, s  \relax \special {t4ht= are evaluated
janafThermo
cp  \relax \special {t4ht= evaluated by a function with coefficients from JANAF thermodynamic tables, from which h  \relax \special {t4ht=, s  \relax \special {t4ht= are evaluated
specieThermo
Thermophysical properties of species, derived from cp  \relax \special {t4ht=, h  \relax \special {t4ht= and/or s  \relax \special {t4ht=
constTransport
Constant transport properties
polynomialTransport
Polynomial based temperature-dependent transport properties
sutherlandTransport
Sutherland’s formula for temperature-dependent transport properties
Functions/tables of thermophysical properties — thermophysicalFunctions
NSRDSfunctions
National Standard Reference Data System (NSRDS) - American Institute of Chemical Engineers (AICHE) data compilation tables
APIfunctions
American Petroleum Institute (API) function for vapour mass diffusivity
Chemistry model — chemistryModel
chemistryModel
Chemical reaction model
chemistrySolver
Chemical reaction solver
Other libraries
liquidProperties
Thermophysical properties of liquids
liquidMixtureProperties
Thermophysical properties of liquid mixtures
basicSolidThermo
Thermophysical models of solids
solid
Thermodynamics of solid species
SLGThermo
Thermodynamic package for solids, liquids and gases
solidProperties
Thermophysical properties of solids
solidMixtureProperties
Thermophysical properties of solid mixtures
thermalPorousZone
Porous zone definition based on cell zones that includes terms for energy equations
Table A.4: Libraries of thermophysical models.
RAS turbulence models — RASModels
laminar
Dummy turbulence model for laminar flow
kEpsilon
Standard k −  ε  \relax \special {t4ht= model
kOmega
k − ω  \relax \special {t4ht= model
kOmegaSST
k − ω − SST  \relax \special {t4ht= model
kOmegaSSTLM
Langtry-Menter 4-equation transitional SST model
kOmegaSSTSAS
k − ω − SST  −  SAS  \relax \special {t4ht= model
LaunderSharmaKE
Launder-Sharma low-Re  \relax \special {t4ht= k − ε  \relax \special {t4ht= model
LRR
Launder-Reece-Rodi RSTM
realizableKE
Realizable k −  ε  \relax \special {t4ht= model
RNGkEpsilon
RN  G − k − ε  \relax \special {t4ht= model
SpalartAllmaras
Spalart-Allmaras 1-eqn mixing-length model
SSG
Speziale, Sarkar and Gatski Reynolds-stress model
v2f
v2 − f  \relax \special {t4ht= model
Large-eddy simulation (LES) filters — LESfilters
laplaceFilter
Laplace filters
simpleFilter
Simple filter
anisotropicFilter
Anisotropic filter
Large-eddy simulation deltas — LESdeltas
PrandtlDelta
Prandtl delta
cubeRootVolDelta
Cube root of cell volume delta
maxDeltaxyz
Maximum of x, y and z; for structured hex cells only
smoothDelta
Smoothing of delta
LES turbulence models — LESModels
DeardorffDiffStress
Differential SGS Stress model
dynamicKEqn
Dynamic one equation eddy-viscosity
dynamicLagrangian
Dynamic SGS model with Lagrangian averaging
kEqn
One equation eddy-viscosity model
Smagorinsky
Smagorinsky SGS model
WALE
Wall-adapting local eddy-viscosity (WALE) model
DES turbulence models — DESModels
kOmegaSSTDES
k − omega  − SST  \relax \special {t4ht= delayed eddy simulation (DES) model
kOmegaSSTDDES
k − omega  − SST  \relax \special {t4ht= delayed detached eddy simulation (DDES) model
kOmegaSSTIDDES
k − omega  − SST  \relax \special {t4ht= improved delayed detached eddy simulation (DDES) model
SpalartAllmarasDES
Spalart-Allmaras delayed eddy simulation (DES) model
SpalartAllmarasDDES
Spalart-Allmaras delayed detached eddy simulation (DDES) model
SpalartAllmarasIDDES
Spalart-Allmaras improved delayed detached eddy simulation (DDES) model
Table A.5: Libraries of RAS, DES and LES turbulence models.
Transport models for incompressible fluids — incompressibleTransportModels
Newtonian
Linear viscous fluid model
CrossPowerLaw
Cross Power law nonlinear viscous model
BirdCarreau
Bird-Carreau nonlinear viscous model
HerschelBulkley
Herschel-Bulkley nonlinear viscous model
powerLaw
Power-law nonlinear viscous model
interfaceProperties
Models for the interface, e.g. contact angle, in multiphase simulations
Miscellaneous transport modelling libraries
interfaceProperties
Calculation of interface properties
twoPhaseInterfaceProperties
Two phase interface properties models, including boundary conditions
surfaceFilmModels
Surface film models
Table A.6: Shared object libraries of transport models.
